BDot310
Feb 01, 2021Aspirant
CM1200 modem NOT WORKING with nighthawk r7000 router
Ok so i have had spectrum all of 2020 with my modem and router working perfectly fine. Last week my router just started not being able to pull a signal from my modem. And when the times it does it las...
Feb 01, 2021Guru - Experienced User
How long did you run it with just modem---pc to ensure the modem connection was good?
What firmware is on the r7000? its not exactly known for the best firmware
- BDot310Feb 01, 2021AspirantI ran it for an entire day. I have had this setup for an entire year with no problems until last week. Yesterday i installed the latest firmware 1.0.11.116 Which was just released on 1/28/21. I installed it after the problems started. I go into the nighthawk dashboard and it says no internet connection to the router. Then i will power cycle the modem and router a few times then it will work for 10-30 min at speeds rather slow then drop out of nowhere. The modem will be fine at speeds of 400+ mbs.
- plemansFeb 02, 2021Guru - Experienced User
The R7000 has had firmware issues. The agreed upon stable version is 1.0.9.42
If this happened after the firmware update, you can always try a factory reset and a clean install. (not from backup)
If that doesn't help, then I'd try downgrading the firmware
