M79
Jul 24, 2021Aspirant
CM1200 modem not working with R7800 router
I just increased my internet speed to 800 so I got the CM1200 and my R7800 will not get an internet signal from it, the R7800 is the only thing plugged into the CM1200, it still works fine with other ...
Jul 25, 2021Guru - Experienced User
So if you power OFF the CM and R units for 30 seconds and power back ON the CM modem first then R router, does the internet LED turn WHITE on the router?
M79
Jul 25, 2021Aspirant
No, it starts off as a solid orange then once the 2.4 and 5 ghz lights are white it starts flickering with them (still orange)
