M79
Jul 24, 2021Aspirant
CM1200 modem not working with R7800 router
I just increased my internet speed to 800 so I got the CM1200 and my R7800 will not get an internet signal from it, the R7800 is the only thing plugged into the CM1200, it still works fine with other ...
M79
Jul 25, 2021Aspirant
No, it starts off as a solid orange then once the 2.4 and 5 ghz lights are white it starts flickering with them (still orange)
Jul 25, 2021Guru - Experienced User
The Internet LED flashes AMBER (orange)?
- FURRYe38Jul 25, 2021Guru - Experienced User
What happens if you use a wired PC and web browser and log into the routers web page and select Setup Wizard from the Advanced Tab while the router is connected to the modem? Select the option of "Let Genie app help you configure the router". Walk thru this method.
- M79Jul 25, 2021AspirantThanks everyone for the great ideas, I have resolved whatever was going on and the router is now working. In case you are interested the firmware was V80 and it said it was up to date, I tried a factory reset again and this time it prompted me to update to V82, after that it seems to work just fine. Thanks again all.đ
Good to hear.
Please mark your thread as solved so others will know.
Be sure to visit the Nighthawk forum for your model router for support additional information:https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Enjoy.
