SunWukong92
Mar 20, 2022Tutor
CM1200 Modem randomly cuts off
Hi everyone, I'm currently having issues with my netgear CM1200. For the last 2 weeks the upstream light has blinked and then gone solid, then the downstream light blinks goes solid, then the ups...
- Mar 20, 2022
here's hoping it stays stable for you!
if it does, I'd mark it solved so others aren't trying to continue to fix a resoled issue đ
Mar 20, 2022Guru - Experienced User
the logs indicate a line issue.
The cable connection page helps in conjunction with the event logs though.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISPâs charge if the wiring issue is in the home. So this helps prevent this.
- SunWukong92Mar 20, 2022Tutor
Hey, sorry i didnt include this however there is only one wire running from the outside box to my house then there is the connector that runs straight to my modem without any other connectors. it goes directly to my modem đ and from the sounds of it you were right it appears there was a "performance issue" that comcast neglected to mention that was being maintenanced today thankfully they went out to check out now for the test of using my internet for the day to see if any more issues arise.
Thank you for the translation of the log and power page. I have no idea how to read it but i know more than enough to troubleshoot on my own and that was the limit of my knowledge.
- plemansMar 20, 2022Guru - Experienced User
