WaveWarper
Jan 11, 2021Aspirant
CM1200 Modem Upstream LED Flashing - Spectrum Internet
I've had this modem for just over a year and it started dropping signal a couple days ago. The upstream LED was flashing green so I had a tech from Spectrum come out and check on everything. They pro...
Marksa17
Mar 15, 2021Aspirant
I read through your post, and one year later seems like the same issue is happening. Is the only recourse to buy another modem?!!? This one is slightly over a year old only just started having issues. Still running the same firmware too. Like OP I've had 3 tech visits, swapped out lines, added/removed/added again amplifier. But constant issues. ISP said maybe an issues with a Node, but to be honest I don't know what that means. I was given the number to the supervisor directly for updates, but I'll let you guess how many times I've spoken to him.
I'll take any/all suggestions, tips, magic enchament spells.. what ever you got.
Marksa17
My specs if anyone cares to take a look.
