ITGL72
May 05, 2021Tutor
CM1200 Modem Using Any Single Port?
On my CM1200 with a PC connected directly to it on port 1 I'm getting about 100 Mbps but if I connected it to port 2 on my CM1200 the speeds jump to about 250 Mbps. Is the modem designed to be ab...
May 05, 2021Guru - Experienced User
have you tried more than 1 device?
And more than 1 cable?
I've seen some sketchy cat 5e cables.
ITGL72
May 06, 2021Tutor
Yes, I've tried connecting to 3 different computers in my house, using different cat5e cables too.
Last night I tried testing connections from all 4 ports, connecting to port 4 was the fastest but is usually around 200-300 Mbps, far from my 1200 Mbps package speed.
- FURRYe38May 06, 2021Guru - Experienced User
I recommend trying CAT6 lan cables. Would perform better than 5e.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- ITGL72May 06, 2021Tutor
Signals pasted at this link.
https://pastebin.com/ex03QtSwI've got my hands on some cat6 cable and will try again.
- plemansMay 06, 2021Guru - Experienced User
signals don't look to bad.
What computer do you have connected you're testing with?
What website are you testing on?
