ITGL72
May 05, 2021Tutor
CM1200 Modem Using Any Single Port?
On my CM1200 with a PC connected directly to it on port 1 I'm getting about 100 Mbps but if I connected it to port 2 on my CM1200 the speeds jump to about 250 Mbps. Is the modem designed to be ab...
ITGL72
May 06, 2021Tutor
Yes, I've tried connecting to 3 different computers in my house, using different cat5e cables too.
Last night I tried testing connections from all 4 ports, connecting to port 4 was the fastest but is usually around 200-300 Mbps, far from my 1200 Mbps package speed.
May 06, 2021Guru - Experienced User
I recommend trying CAT6 lan cables. Would perform better than 5e.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- ITGL72May 06, 2021Tutor
Signals pasted at this link.
https://pastebin.com/ex03QtSwI've got my hands on some cat6 cable and will try again.
- plemansMay 06, 2021Guru - Experienced User
signals don't look to bad.
What computer do you have connected you're testing with?
What website are you testing on?
- ITGL72May 07, 2021Tutor
I'm using DSL Reports, Fast.com, SpeedTest.net, and the Xfinity speed test site. They always vary which is expected but sometimes you wonder.
I have two different tower PCs that I connect via cat6 ethernet ports.
Anyway I had a tech over yesterday and the signal coming into the house from the street seemed fine with nearly 1000 Mbps coming to the modem.
So, I'm swapping out hardware later to the Netgear wifi-router-modem combo device because on top of all this the drop from the modem to the netgear r7000p I hooked up earlier in the week is quite a bit. Turned Armor off, QOS disabled, says no firmware updates needed but it gets between 250 350 or lower Mbps at the switch ports. Thats using different cat6 cables, computers, different port orientations.
