gpaul
Apr 07, 2020Initiate
CM1200 modem wont connect to the internet despite green LEDs
I pulled out an older netgear modem and I installed a new CM1200 and then called Spectrum to activate it. Once they activated it I had four solid green leds on the front of the modem. Spectrum was ...
- Apr 13, 2020
Solved - despite the four green LEDs on the modem suggesting it was officialy conneceted, a character in the MAC address was incorrect. Why the MAC address authority allows "B" and "8" to coexist and be printed in capitals is beyond me.... Same issue with "0" and "O".
Apr 08, 2020Guru - Experienced User
Connect your PC to LAN Port #1 of the modem and power it OFF for 1 minute then back on. Reboot your PC as well.
After the mode is online, check internet access. Besure to clear all web browser caches.
Try a different browser to test.
Do you can to netgear.com with out the activation page appearing?
