One9Delta
Mar 27, 2020Aspirant
cm1200 modem
So I bought a new modem to handle gigablast back in Dec. and have had no issues I also want to state that I have the R7000 router(which i think the ports have gone bad but thats a different issue) an...
- Mar 29, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
One9Delta
Mar 29, 2020Aspirant
If im getting lag spikes of 20ms upward to 500ms is that traffic at the modem or from the ISP? I have a warranty on the modem I just need to know if getting a new modem will solve this spikes or is it ISP related. I trying to rule out all the sources.
