rjcook450
Nov 17, 2020Aspirant
Cm1200 modem
I just instlled a cm1200 modem. After connecting it with ISP I can get onto internet but only through Edge. Firefox gives this error.
Log in to network
Firefox can’t load this page for some reason.
has a security policy called HTTP Strict Transport Security (HSTS), which means that Firefox can only connect to it securely. You can’t add an exception to visit this site.
Websites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for www.msn.com. The certificate is only valid for the following names: myaccount.cableone.net, myaccount.sparklight.net, myaccount.sparklight.com, signup.cableone.net, mysignup.cableone.net
Error code: SSL_ERROR_BAD_CERT_DOMAIN
I had no issues with previous modem that ISP provided other than it was years old, and i just installed xr1000 router a week ago and wanted to go all netgear.
1 Reply
- rjcook450Aspirant
After digging around, problem was in router not modem, I had to set IPv6 to autoconfig, it was disabled when using older modem.
