weeeeeee
Mar 08, 2024Follower
CM1200 modem
Can ADT and Roko be connected to the WAN ports of a CM1200 Modem? What are the pros and cons of set up my network that way?
CrimpOn
Mar 08, 2024Guru - Experienced User
No. This DOSIS 3.1 cable modem is intended to be connected to a consumer router. See the installation guide:
https://www.downloads.netgear.com/files/GDC/CM1200/CM1200_All_MSOs_QSG_EN.pdf
At the time this modem was introduced, it was not common to have Ethernet ports supporting higher than gigabit speeds on consumer products. Since DOCSIS 3.1 supports cable speeds greater than gigabit, this modem and a number of consumer routers featured Link Aggregation which uses more than one gigabit Ethernet link to support higher speeds.
More modern DOCSIS 3.1 modems have a single Ethernet port supporting 2.5 or even 10Gbit links. And, more modern consumer router also support Ethernet ports with higher speeds.
Link Aggregation has now "faded away".
