Tracy91
Sep 25, 2020Aspirant
CM1200 New high MS
Hello all, I am currently using a CM1200 modem and an Asus RT-5300 router. I haven't been at this house for a month yet and I have had issues with the Optimum services since I had initially had t...
Tracy91
So here's a better explanation. telephone Line to house > Outside splitter that splits to attic/living room > Travels through the wall to the Inside splitter in my living room > My modem/router. The outside splitter had a cable going into the attic in which i disconnected everything in the attic, but I didn't remove that cable. Should I pursue removing that cable from the outside splitter?. Are you asking to disconnect the living room splitter and connect that cable directly to my modem? Thanks in advance. Cable connections page:
| Apply Cancel | |
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 609000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
| IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 14 | 609000000 Hz | 1.6 dBmV | 40.3 dB | 0 | 0 |
| 2 | Locked | QAM256 | 1 | 519000000 Hz | 4.3 dBmV | 42 dB | 0 | 0 |
| 3 | Locked | QAM256 | 2 | 525000000 Hz | 4.2 dBmV | 41.9 dB | 0 | 0 |
| 4 | Locked | QAM256 | 3 | 531000000 Hz | 4.1 dBmV | 41.9 dB | 0 | 0 |
| 5 | Locked | QAM256 | 4 | 537000000 Hz | 4 dBmV | 41.8 dB | 0 | 0 |
| 6 | Locked | QAM256 | 5 | 543000000 Hz | 3.7 dBmV | 41.7 dB | 0 | 0 |
| 7 | Locked | QAM256 | 6 | 549000000 Hz | 3.6 dBmV | 41.6 dB | 0 | 0 |
| 8 | Locked | QAM256 | 7 | 555000000 Hz | 3.4 dBmV | 41.4 dB | 0 | 0 |
| 9 | Locked | QAM256 | 8 | 561000000 Hz | 3.2 dBmV | 41.3 dB | 0 | 0 |
| 10 | Locked | QAM256 | 9 | 567000000 Hz | 3 dBmV | 41.1 dB | 0 | 0 |
| 11 | Locked | QAM256 | 10 | 573000000 Hz | 2.9 dBmV | 41.1 dB | 0 | 0 |
| 12 | Locked | QAM256 | 11 | 579000000 Hz | 2.6 dBmV | 40.9 dB | 0 | 0 |
| 13 | Locked | QAM256 | 12 | 585000000 Hz | 2.4 dBmV | 40.8 dB | 0 | 0 |
| 14 | Locked | QAM256 | 13 | 603000000 Hz | 2.1 dBmV | 40.5 dB | 0 | 0 |
| 15 | Locked | QAM256 | 15 | 615000000 Hz | 1.4 dBmV | 40.1 dB | 0 | 0 |
| 16 | Locked | QAM256 | 16 | 621000000 Hz | 1.3 dBmV | 40 dB | 0 | 0 |
| 17 | Locked | QAM256 | 17 | 627000000 Hz | 1.2 dBmV | 40 dB | 0 | 0 |
| 18 | Locked | QAM256 | 18 | 633000000 Hz | 0.8 dBmV | 39.9 dB | 0 | 0 |
| 19 | Locked | QAM256 | 19 | 639000000 Hz | 0.8 dBmV | 39.9 dB | 0 | 0 |
| 20 | Locked | QAM256 | 20 | 645000000 Hz | 0.7 dBmV | 39.8 dB | 0 | 0 |
| 21 | Locked | QAM256 | 21 | 651000000 Hz | 0.6 dBmV | 39.7 dB | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 657000000 Hz | 0.3 dBmV | 39.6 dB | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 663000000 Hz | 0.4 dBmV | 39.7 dB | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 669000000 Hz | 0.5 dBmV | 39.8 dB | 0 | 0 |
| 25 | Locked | QAM256 | 25 | 675000000 Hz | 0.5 dBmV | 39.1 dB | 0 | 0 |
| 26 | Locked | QAM256 | 26 | 681000000 Hz | 0.2 dBmV | 39.7 dB | 0 | 0 |
| 27 | Locked | QAM256 | 27 | 687000000 Hz | 0.3 dBmV | 39.6 dB | 0 | 0 |
| 28 | Locked | QAM256 | 28 | 693000000 Hz | 0.3 dBmV | 39.7 dB | 0 | 0 |
| 29 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 30 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 31 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 14000000 Hz | 32 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 22000000 Hz | 33.8 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 28400000 Hz | 34.8 dBmV |
| 4 | Locked | ATDMA | 5 | 2560 Ksym/sec | 39800000 Hz | 35.3 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 159 | 714000000 Hz | 0.0 dBmV | 38.8 dB | 1588 ~ 2507 | 78866564 | 11582643 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Fri Sep 25 10:38:11 2020System Up Time:01:05:53
Sep 25, 2020Guru - Experienced User
you've got low upstream and a bit of variation in the downstream.
I'd remove the outside splitter and just off the cable going to the living room. If its needed for cabler tv, just for the time being, don't use it. Just go cable----->modem. with no splitters. See how it works and after using it for a bit, then rerun the logs and cable connections page. See how stable it stays.
- Tracy91Sep 25, 2020Aspirant
Checked outside and it goes line to the initial cable into the living room at this point then to the splitter.. Going to connect directly to the modem and get rid of the splitter and see what happens. I'm actually calling my ISP again at this time to see what's going on. I checked the cable that goes from outside to inside and its RG 6. Wiring to the attic has been disconnected from the outside as well. I'm confused to what's going on at this point.
