Azriel
Aug 21, 2019Follower
Cm1200 not connected to smarthome
Purchased smart home with echo dot, SmartThings hub, Honeywell thermostat, ring doorbell, Kwikset smart door lock all connected to a Ruckus ICX 7150-C12P. My X10 is connected to the CM1200 and so is ...
antinode
Aug 21, 2019Guru
> [...] My X10 is connected to the CM1200 and so is the ICX 7150-C12P.
Connect WAN/Internet port of the "X10" (not a model number) router to
the "LAN 1" port of the CM1200. Connect the switch to a LAN port on the
"X10".
Visit http://netgear.com/support , put in your modem model number,
and look for Documentation. Get the User Manual. Read. Look for "LAN
ports". Keep reading.
