tanviper
Nov 24, 2019Aspirant
CM1200 not working with wireless routers
I went from cox's 150 internet service to their gigablast service yesterday. I knew I was going to need a new modem as my old one wasn't 3.1. I purchased the Netgear CM1200 and got it setup. My compu...
JasGr81
Feb 02, 2020Aspirant
I was using a switch but wasn’t getting the speed that I was previously getting so I removed the switch completely and the speeds went back up around 115 Mbps. With the switch I was only getting around 70 Mbps.
Feb 02, 2020Guru - Experienced User
Is the switch rated for 100Mbps or 1000Mpbs connection rates?
Also the switch should be installed after a router, not between the modem and router.
