spoonbandits
Sep 06, 2021Aspirant
CM1200 only getting 120mbps
Anyone have any idea on how to resolve this? I've got a brand new CM1200 - called the cable company and gave them MAC address, they said no compatibility problems. I've got port 1 plugged in to my ...
- Sep 07, 2021
Who is your ISP?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them ensure the channels they are supporting are being locked in on the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Sep 06, 2021Guru - Experienced User
Disconnect the ASUS router and directly connect 1 wired 1Gb ethernet supported PC to the CM modem. Power off the modem for 1 minute then back on. Check the speeds with Ooklas installable speed test app with the PC.
Please post a copy and paste of the modems connection status page.
spoonbandits
Sep 07, 2021Aspirant
I followed the recommend steps, still only getting 120mpbs on my connected PC.
I noticed that not all channels are "Locked" in the status screen:
- spoonbanditsSep 07, 2021Aspirant
Here are the event logs:
- FURRYe38Sep 07, 2021Guru - Experienced User
Who is your ISP?
Be sure your using good quality RG6 coax cable up to the modem.- spoonbanditsSep 07, 2021Aspirant
Got it sorted! Thanks!
I had to speak with the ISP again, the previous technician added the correct MAC address, but something was not correct in their system and they needed to manually provision the new modem.
