spoonbandits
Sep 06, 2021Aspirant
CM1200 only getting 120mbps
Anyone have any idea on how to resolve this? I've got a brand new CM1200 - called the cable company and gave them MAC address, they said no compatibility problems. I've got port 1 plugged in to my ...
- Sep 07, 2021
Who is your ISP?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them ensure the channels they are supporting are being locked in on the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
spoonbandits
Sep 07, 2021Aspirant
Here are the event logs:
Sep 07, 2021Guru - Experienced User
Who is your ISP?
- spoonbanditsSep 07, 2021Aspirant
Got it sorted! Thanks!
I had to speak with the ISP again, the previous technician added the correct MAC address, but something was not correct in their system and they needed to manually provision the new modem.
- FURRYe38Sep 07, 2021Guru - Experienced User
Enjoy.
