syntax
Jan 17, 2022Aspirant
cm1200 or cm2000
I got charter gigabit plan with eero pro wifi 5 router with EN2251 with puma 7 i get speed on wifi 5 around 500mbps but in my room i get 400mbps. Should i get a new. modem or new router? If i g...
Jan 17, 2022Guru - Experienced User
what speed do you get directly connected to the modem?
Are you speed testing directly attached to the router or over wireless?
