syntax
Jan 17, 2022Aspirant
cm1200 or cm2000
I got charter gigabit plan with eero pro wifi 5 router with EN2251 with puma 7 i get speed on wifi 5 around 500mbps but in my room i get 400mbps. Should i get a new. modem or new router? If i g...
syntax
Apr 02, 2022Aspirant
With ETH0 around 700 to 900mbps
Apr 02, 2022Guru - Experienced User
so you're modem is doing fine. Upgrading the modem isn't going to increase your speeds.
Usually the bottleneck is in the device you're testing on and not on the router/modem.
- syntaxJun 02, 2022Aspirant
Hi,
I am use a Eero pro Wifi 5 router with a docs 3.1 modem.
- plemansJun 02, 2022Guru - Experienced User
So the modem is doing its job. The router is even doing its job. I think its just a misunderstanding of the performance of wifi.
I'd recommend reading this article (don't have to read all of it but it gives a good over view).
https://www.duckware.com/tech/wifi-in-the-us.html
It dispels quite a few wifi misunderstandings.
