syntax
Jan 17, 2022Aspirant
cm1200 or cm2000
I got charter gigabit plan with eero pro wifi 5 router with EN2251 with puma 7 i get speed on wifi 5 around 500mbps but in my room i get 400mbps. Should i get a new. modem or new router? If i g...
syntax
Jun 02, 2022Aspirant
Hi,
I got a router and switch Question. I was thinking of get a new router I have a Eero pro wifi5 and when I get 3 node. What it does it slow the 3 one down. When I have 2 node on it work fine.
I do had a network switch connect to it. I have a charter gigiabit 940 35 upload plan.Should I get a better wifi router like Orbi?
- plemansJun 02, 2022Guru - Experienced User
did you check with eero? Maybe its an easy fix but they'd have a better idea on their forums than on the netgear ones.
You can compare the reviews ratings on mesh systems. I'm a fan of dong knows.
https://dongknows.com/best-wi-fi-6-mesh-systems/
