ImHaywire
Nov 25, 2019Follower
CM1200 port aggregation on 1/2 AND 3/4?
Working in tech support from home, I want to keep my lab/work network separate from the families. I run PFsense on an old PC for my router/firewall. The fam has the Asus RT-AC3100. I've had several o...
Nov 26, 2019Guru - Experienced User
Does not support dual WAN.
Have you tried putting the PFsence on port 1 and the Asus router on port 2? I have my CM1100 setup this way for two router support. LAG not enabled on the CM modem. Its working on my 1Gb ISP network.
