Slimeknight
Jan 15, 2021Aspirant
CM1200 problems?
I've had this modem and router setup going for a while now. Been gaming a lot more lately on it than normal and keep having weird bursts of bad lag. In game MS appears to be fine most of the time b...
Slimeknight
Jan 16, 2021Aspirant
Slimeknight
- plemansJan 16, 2021Guru - Experienced User
both the logs and cable connections page show errors/problems with the line.
I'd remove any spliters, amplifiers, or attenuators from the line. Also check the line for any damange, kinks, extended runs, loose/cheap/bad/old connectors.
If none of that helps, contact your isp to check the line.
- FURRYe38Jan 16, 2021Guru - Experienced User
Be sure your using good quality RG6 coax cable up to the modem.
