Scopoletus
Nov 27, 2020Tutor
Cm1200 rebooting every 5-10 minutes.
My modern reboots about every ten minutes. I have called my cable company (spectrum) and they sent out a tech that told me all the signals were good and that the modern seems to be the problem. I cal...
Nov 28, 2020Guru - Experienced User
do you have a screen snip of the cable connections page and the logs?
Also, have you direct connected a pc to the cm1200 and ran it for a period of time? if it happens every 10 minutes, you should fairly quickly be able to tell if it truly is the modem loosing connection.
- ScopoletusNov 28, 2020Tutor
I have left both the Modem and router off last night and rebooted this morning. Same issue. I have now been on the Modem directly for about 20 min with no interuptions.
Lost connection right as i posted the last post.
- plemansNov 28, 2020Guru - Experienced User
did you have the cable connections page?
When you post them as a photo, a moderator has to approve it and it can take days to be approved.
click on "choose file" and just post them individually
