Scopoletus
Nov 27, 2020Tutor
Cm1200 rebooting every 5-10 minutes.
My modern reboots about every ten minutes. I have called my cable company (spectrum) and they sent out a tech that told me all the signals were good and that the modern seems to be the problem. I cal...
Scopoletus
Mar 01, 2021Tutor
Silenced78 No it did not. I have called Netgear and talked to the techs there and they just tell me to run through the troubleshooting that has already been completed and that my 90 day tech support is over and I need to pay $70 so them to look at the software. I will be calling again to try to get a new unit as I have replaced it with a modem from my IPS which has been working with no issues. This is not a software issue. I have gone through every port with the same outcome. They tell me it is an issue with the connection to the router but I get the issue going straight to my computer. They obviously dont know or want to help unless you pay the $$$.
Scopoletus
Mar 01, 2021Tutor
Getting a new replacement unit. Hopefully this helps someone. You will have to deal with the normal BS of them not wanting to replace thier units. Hopefully this will be a fix.
