Telcontarr
Feb 26, 2021Aspirant
CM1200 Repeated Disconnects
Hello, I am experiencing problems with my CM1200 repeatedly disconnecting and reconnecting multiple times unpredictably. I have proceeded with all the usual steps of disconnect and power off, wait ~...
Feb 26, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- TelcontarrFeb 26, 2021Aspirant
Thanks! I'll have them check those things, I don't think there are any splitters in the line.
Do you have a recommendation for a good RG6 cable to use?- FURRYe38Feb 26, 2021Guru - Experienced User
The ISP should have good RG6 Coax to use...
- TelcontarrMar 24, 2021Aspirant
Had a second follow up visit on the issue and the Spectrum techs said everything looked fine from their end and saw no router failures, even when there were drops this morning before they got here. I can't determine what's going wrong or where. Here are the event logs if anyone can help me understand what I'm seeing. Tech took a look and said "I can't do anything with your personal equipment".
Wed Mar 24 10:13:44 2021 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:44 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:43 2021 Warning (5) Dynamic Range Window violation Wed Mar 24 10:13:43 2021 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:43 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:37 2021 Warning (5) Dynamic Range Window violation Wed Mar 24 10:13:37 2021 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:37 2021 Warning (5) Dynamic Range Window violation Wed Mar 24 10:13:37 2021 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:37 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:33 2021 Warning (5) Dynamic Range Window violation Wed Mar 24 10:13:33 2021 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:33 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; Wed Mar 24 10:13:27 2021 Warning (5) Dynamic Range Window violation Wed Mar 24 10:13:27 2021 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1;
