Telcontarr
Feb 26, 2021Aspirant
CM1200 Repeated Disconnects
Hello, I am experiencing problems with my CM1200 repeatedly disconnecting and reconnecting multiple times unpredictably. I have proceeded with all the usual steps of disconnect and power off, wait ~...
Telcontarr
Mar 24, 2021Aspirant
Had a second follow up visit on the issue and the Spectrum techs said everything looked fine from their end and saw no router failures, even when there were drops this morning before they got here. I can't determine what's going wrong or where. Here are the event logs if anyone can help me understand what I'm seeing. Tech took a look and said "I can't do anything with your personal equipment".
| Wed Mar 24 10:13:44 2021 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:44 2021 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:43 2021 | Warning (5) | Dynamic Range Window violation |
| Wed Mar 24 10:13:43 2021 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:43 2021 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:37 2021 | Warning (5) | Dynamic Range Window violation |
| Wed Mar 24 10:13:37 2021 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:37 2021 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:33 2021 | Warning (5) | Dynamic Range Window violation |
| Wed Mar 24 10:13:33 2021 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:33 2021 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
| Wed Mar 24 10:13:27 2021 | Warning (5) | Dynamic Range Window violation |
| Wed Mar 24 10:13:27 2021 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:c3:d0;CMTS-MAC=00:17:10:86:bd:cb;CM-QOS=1.1;CM-VER=3.1; |
Telcontarr
Mar 27, 2021Aspirant
I'm getting really tired of dealing with problems with Netgear equipment. Is there no support to tell me what's going wrong?
- FURRYe38Mar 27, 2021Guru - Experienced User
Seeing lots of uncorrectables on the status table. Seems that the mofem can't get a good signal or having problems with the signal on the line.
What Version of FW is loaded on the modem?
- TelcontarrMar 27, 2021Aspirant
During the last Spectrum technician visit, they said the signal from their tap to the house to the modem itself was "perfect". They technician saw no reported failures or outages in their signal over the last 7 days, despite me experiencing these disconnections frequently over the course of a a day for a week or more.
Current Firmware is V1.02.01, but Spectrum has not updated the approved firmware.Is there something else I could be missing? A power supply issue to the modem?
- FURRYe38Mar 28, 2021Guru - Experienced User
Good luck in getting Spectrum to update modem FW. I believe there ones that don't for user owned modems. Can do a search here in the forums regarding Spectrum and user owned modems.
Can try a different power supply to see. Ensure its the same voltage and amps as on the NG supply that came with the modem.
