adamfong11
Sep 06, 2020Follower
CM1200 Router Ports
So I have been trying to do some reseach and I have read the other posts about the ethernet ports on the CM1200, but it isn't explicitly clear. What I am trying to do is to connect a wireless r...
CalCal23
Sep 08, 2020Apprentice
Have you tried an unmanaged switch?? You can connect it to an open ethernet port on your router (not cable modem) and it will provide you with additional ethernet ports. You router will control the IP addresses. Unmanaged switches can be set up all over your residence. They are automatic in that they will detect the ethernet port with the incoming connection and make all of the other ports usable for internet access through your router.
For the time being, just use the top port (port 1) on the CM1200. That is the port that will get your internet connectivity from you ISP. Connect that to the internet port of your router and you should be good to go. Just remember about the unmanaged switches. I've hard wired just abou t everything in my condo and it's awesome. Only my mobile devices are on WiFi so, I get great speeds on everything. Also, make sure you have enough bandwidth to support all of your devices....gaming, 4K streaming, office work, etc.
The introductory prices for Gigabit service, if it's available in your area should be competitive, especially if you negotiate with the ISP.
