AJM0624
Sep 16, 2023Aspirant
CM1200 setup issue
I connected and powered up my CM1200 modem, then activated it with my ISP (Xfinity). I use a Mac so no ethernet cable to connect to the modem with. I tried to connect directly to the modem using th...
Sep 16, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
AJM0624
I have turned off modem and router, unplugged everything, then powered on modem and waited until it fully reboots to ppint of Online LED solid. Then I plugged in cable to router and powered it on. When it completes its startup the Online LED is Red.
I'm suppose to be able to connect to the modem using a direct access IP address. But it tells me to connect a computer to the router wirelessly. I can't seem to do that and I'm using a Mac so no ethernet port.
- FURRYe38Sep 16, 2023Guru - Experienced User
Can you find a USB to ethernet adapter? Usually cheap to find online.
- AJM0624Sep 16, 2023Aspirant
Guess I'm going to need to do that. Thanks.
- KitsapSep 16, 2023Master
You cannot connect direct to the modem via a wireless connection. The modem contains no Wi-Fi hardware.
From your description, your modem may be connecting fine. If you go to the Downloads section above, feed in the model number of your router (look on the label after the words model number) you can download the user manual.
The user manual usually has a section called troubleshooting with LEDs. Note, the user manual will use the color amber to describe what you are calling red.
