TobyBaroby
Aug 23, 2021Follower
Cm1200 slowdowns on a regular basis
HARDWARE: CM1200 (Firmware V3.12.03) TP-Link Archer 1500 (Firmware 1.2.0 Build 20210421 Rel. 64516(5553)) Xifinity Gigabit Cable (1200 down, 45 up) On a normal day on my wired PC connection I ...
Aug 23, 2021Guru - Experienced User
Test the speed with out the wifi router in the mix. Connect a wired PC to the modem and speed test there.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
