Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
YoungSpicket
Jul 21, 2019Star
I have the same thing happen on this modem as well as my Motorola Mb8600 so it’s definitely a Comcast issue. After 48 hours or so speeds drop to a max of about 650mbps with LACP enabled.
Skeeterslint667
Jul 21, 2019Star
Mine drop lower then that, my download ends up well below 100Mbps typically down to about 20 or 30. First I have seen on any forum about other modems having the same problem.
