Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
Skeeterslint667
Jul 19, 2019Star
Pokemaniac wrote:If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 and 48 hours of uptime. The only thing which seems to fix this is rebooting the CM1200. Additionally, I've had it running for at least a week now with Link Aggregation disabled, and I'm not seeing any slowdown, so it would appear that Link Aggregation is related to the problem.
The firmware of the CM1200 shows up as V1.01.02, for reference.
I have a CM1150v on firmware 2.02.04 (which is the lastest Comcast just pushed it recently in the past week) and when I turn on LAG my connection will slow down within 24 hours, it did the same on the previous firmware 2.02.03. So there is something definitely not right in the firmware that is causing this to happen and this is the first post I have seen on the Netgear forum that talks about this issue. My ISP is Comcast and my speed tier is their gigabyte plan. I have never had it last longer then 24 hours before the speed degrades.Also i might add that my CM1150v is a beta unit that I was sent in the beta test for this device on Comcast.
CGASTON
Jul 21, 2019Guide
Here is the issue and fix. I have the same moden and the Nighthawk AX8 router. My modem was giving me speeds at the average 900's mb/sec and every 12hrs, the speeds would drop to 12mb/sec. I would the reset the modem and the speeds would increase to my 900's mb/sec speeds. I then tried aggregation and it worked for a couple of days my speeds stayed at 900's mb/sec without issue then it began to drop back to 12mb/sec. With the AX8, you can test speeds directly from the router/modem and then I would test the speeds on my Nvidia Shield and they would match. First, Comcast is pissed that you are using their modem for $13/month. Secondly, you will actually have to contact a technical support supervisor. So I decided to call XFINITY (Comcast) and raise hell. They first began to speak me me as I am an idiot and dont know anything. You will have to reiterate that the Nighthawk CM1200 is compatible to their network and is also listed on their website. They ask you speedtest questions and things. Then they will talk down to you. Log into your modem and tell them you can see the frequency and they are not what they should be. Now asked them to bump up your speeds and then lock in the modem. They will argue a bit but they have to do it. Once modem is locked in I. And speeds are bumped, you will not have to restart the modem every 12-24hrs. They are trying to force you to use their modem which then dictates the speeds your devices are allowed to get.
P.S. I have a Galaxy S10 5g, and need to know how to configure the wifi settings to get almost gigabit speeds on 5Ghz. I can only get 325-450mb/sec, which I know the phone is capable of faster speeds
