Pokemaniac
Jul 12, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
kvanals
Jul 22, 2019Star
So I'm having the exact same issue -- with 802.3ad link aggregation (LACP/LAG) enabled, after about 24 hours my speeds drop from gigabit to 20-30Mbit/s. I am on firmware version 1.02.02 and hardware version 1.01. Rebooting solves the issue until it comes back. It's a real bummer and the only reason I bought this modem. I've only had it for a week or so.
CGASTON
Jul 22, 2019Guide
Did you read my post????? It is not the modem, it is Comcast. Read my post and do AS I did and it will fix your issues
- kvanalsJul 22, 2019Star
Hey there, I did read your post, but I'm not sure that I really understand what you're on about. My cable modem frequencies are unchanged from when the issue is occurring versus when they are not. Furthermore, the signal to noise ratios (SNR) look amazing (around 42dB) and I'm showing no uncorrectable errors on any channel and little no correctable errors as well, shockingly. What were your statistics like prior to calling Comcast? I'm curious what statistic or metric I can point them to to indicate that there is a specific problem, since I'd love for it to be as easy as calling technical support and getting them to do something. With no indication that the issue is indeed on their side, it's hard to justify "raising hell", as much as we all like yelling at Comcast.
A metric that I do find interesting is that I see increased latency, upwards of 300ms RTT, to the cable modem's management IP itself (192.168.100.1) when this issue is occurring. This leads me to believe it's a runaway process of some kind on the device rather than an upstream issue.
- PokemaniacJul 23, 2019Aspirant
I've been having these issues with RCN, as well, so it is clearly not something entirely specific to Comcast.
- CGASTONJul 23, 2019GuideI dont have an issue. So believe me or not.
- kvanalsJul 23, 2019Star
CGASTON: It's not that we don't believe you; it's just that without any metrics to go over with the ISP to indicate the problem is on their side, it's hard to justify calling and asking them to do something about it. Since the issue seems to be across multiple ISPs and the fact that disabling link aggregation resolves the issue, it would make more sense to be related to the CM1200 rather than the upstream provider.
Having said that, since you're no longer having the issue, can you provide screenshots showing that link aggregation is indeed still enabled, the firmware version, and showing the system up time is over 48 hours?
