Pokemaniac
Jul 12, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
CGASTON
Aug 06, 2019Guide
You know this thread is pretty funny. I gave my suggestion and what to do to get the situation fixed and nobody has yet to reach out and try mine solution. I've done it my ship works I get one gig download speed constant no problems ask in no issues or resetting every 12 hours or every day. Quit thinkin it's your modem and router and try the simple fix I did simple enough
cursixx
Aug 06, 2019Star
Ignorance is bliss and I'm glad that is working for you but clearly you are not using LACP with the CM1200. I encourage you to do more research on the subject before contributing further with useless information.
