Pokemaniac
Jul 12, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
retate
Sep 25, 2019Star
ray102382 wrote:No way to do this without a managed switch? Running an R7960P and CM1200. I have to remote into the PC and into the web interface to reboot it. Could I disable and re-enable the LACP function to gain the same effect?
The CM1200 reboots when you enable LACP so a disable and re-enable of LACP on it may restore performance, but with a couple minutes or more outage. If you can disable / enable LACP on the device that the CM1200 is connected to that may restore performance.
ray102382
Sep 25, 2019Aspirant
I tried to disable it on the R7960P and it triggers a reboot as well. So I guess no easy way around it. I removed the second connection and turned of aggreation all together for now.
