Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
ThePiston450
Nov 23, 2019Tutor
Having the same problem here. Opened a support ticket when first purchased but got the run around from net gear blaming Comcast for the issue. I have the rax120 router with cm1150 modem with latest firmware on both. I can confirm same findings, modem reset fixes issue after 24 hours of speed decrease. I wish netgear would fix this issue. I can also see that single wan on gigabit shows download of 940 and wan aggregation brings it to 1190. So it does benefit the gigabit connection. Netgear, please fix. All my channels are locked and signals are perfect in cable modem GUI also.
- FURRYe38Nov 25, 2019Guru - Experienced User
Please post in this thread for your model modem:
This issue only for the CM1200.
