Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
blew88
Jan 12, 2020Aspirant
CM1200 modem, AX12-RAX120 router, 1Gbps download Comcast Bay Area setup here. Having the same issues as everyone else with Link Aggregation Control Protocol. Hopeful that Netgear support is working on this and will provide a fix in firmware.
- L3XANDR0Jan 12, 2020AspirantI upgraded to a WiFi 6 router with a 2.5 gbps port, and I am no longer seeing a slowdown. I wasn't using link aggregation. The router is the Asus Rapture AX11000.
- ray102382Feb 13, 2020Aspirant
Still no luck? I dont want to have to replace the modem. But at this point its not worth holding out.
- sterlingsandersFeb 13, 2020Guide
Just disable link aggregation.
- cursixxFeb 13, 2020StarZoom/Motorola is bring a 2.5gb interface modem to market this spring. MB8611 is going to be the model and I'm hold out for it. I would still like to see a sfp+ modem.
- FURRYe38Feb 14, 2020Guru - Experienced User
https://www.netgear.com/home/products/networking/cable-modems-routers/cax80.aspx
