Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
ray102382
Feb 13, 2020Aspirant
Still no luck? I dont want to have to replace the modem. But at this point its not worth holding out.
cursixx
Feb 13, 2020Star
Zoom/Motorola is bring a 2.5gb interface modem to market this spring. MB8611 is going to be the model and I'm hold out for it. I would still like to see a sfp+ modem.
- FURRYe38Feb 14, 2020Guru - Experienced User
https://www.netgear.com/home/products/networking/cable-modems-routers/cax80.aspx
cursixx wrote:
Zoom/Motorola is bring a 2.5gb interface modem to market this spring. MB8611 is going to be the model and I'm hold out for it. I would still like to see a sfp+ modem.- branchbikerFeb 24, 2020Apprentice
I replaced it with a CM1100 and noticed that while degradation is gone, when I enable LAG, the speed drops by about 200mbps (from 950 to 650). Is that normal? Will that be fixed?
- FURRYe38Feb 24, 2020Guru - Experienced User
branchbiker wrote:I replaced it with a CM1100 and noticed that while degradation is gone, when I enable LAG, the speed drops by about 200mbps (from 950 to 650). Is that normal? Will that be fixed?
