Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
AdeptMaven
Aug 20, 2020Guide
Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
Cm1200>RAX120
- FURRYe38Aug 20, 2020Guru - Experienced User
Please report your findings in another day or two...
AdeptMaven wrote:Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
Cm1200>RAX120- DirtyPatriotAug 20, 2020GuideI've been stable for 5 days now. Have been running speed tests every evening. Still pulling 1200down 42up. I am considering this issue finally resolved. Crazy it took a year but grateful nonetheless.
- ray102382Aug 20, 2020Aspirant
So how does one get this firmware? I called into Spectrum and they said they have no updates for personally owned devices.
- AdeptMavenAug 24, 2020Guide
Happy to report that I've had Link Agg enabled for 5 straight days and no slow downs or other issues. Now just wish Intel could fix the AX200 drivers then all would be well in my network
