Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
AdeptMaven
Aug 20, 2020Guide
Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
Cm1200>RAX120
Aug 20, 2020Guru - Experienced User
Please report your findings in another day or two...
AdeptMaven wrote:Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
Cm1200>RAX120
- DirtyPatriotAug 20, 2020GuideI've been stable for 5 days now. Have been running speed tests every evening. Still pulling 1200down 42up. I am considering this issue finally resolved. Crazy it took a year but grateful nonetheless.
- ray102382Aug 20, 2020Aspirant
So how does one get this firmware? I called into Spectrum and they said they have no updates for personally owned devices.
- AdeptMavenAug 20, 2020GuideUnfortunately it's entirely up to the ISP. I have Comcast/Xfinity and they just pushed the firmware the morning of 8/19/2020.
- FURRYe38Aug 20, 2020Guru - Experienced User
Good to hear. Thanks for letting us know.
DirtyPatriot wrote:
I've been stable for 5 days now. Have been running speed tests every evening. Still pulling 1200down 42up. I am considering this issue finally resolved. Crazy it took a year but grateful nonetheless. - sterlingsandersAug 20, 2020Guide
Alright, guess I'll test this today then. My router updated at 12am yesterday. Will keep you all posted as well.
You mean your modem updated?
let us know what you see in a couple of days with LAG enabled.
sterlingsanders wrote:Alright, guess I'll test this today then. My router updated at 12am yesterday. Will keep you all posted as well.
- AdeptMavenAug 24, 2020Guide
Happy to report that I've had Link Agg enabled for 5 straight days and no slow downs or other issues. Now just wish Intel could fix the AX200 drivers then all would be well in my network
- FURRYe38Aug 24, 2020Guru - Experienced User
THank you for letting us know. Glad this is fixed now.
You'll have to post about any Intel problems over in there forums and let them know.
Enjoy. :smileywink:
AdeptMaven wrote:Happy to report that I've had Link Agg enabled for 5 straight days and no slow downs or other issues. Now just wish Intel could fix the AX200 drivers then all would be well in my network
