Pokemaniac
Jul 11, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
sterlingsanders
Aug 20, 2020Guide
Alright, guess I'll test this today then. My router updated at 12am yesterday. Will keep you all posted as well.
Aug 20, 2020Guru - Experienced User
You mean your modem updated?
let us know what you see in a couple of days with LAG enabled.
sterlingsanders wrote:Alright, guess I'll test this today then. My router updated at 12am yesterday. Will keep you all posted as well.
- sterlingsandersAug 24, 2020Guide
I can officially say that this problem looks to be solved. I've had a little more than 78hours of uptime in Link Aggregation between the CM1200 and the RAX200. No drops in speed, no slow downs, no service interuptions and actually the speeds definitely feel more consistent in both wired and wireless clients.
Please shout with any questions. Finally seems to be fully functioning. I'm happy it works, but still rather miffed/annoyed that it took a year for a primary, advertised feature to become fully functional.
Full Setup:
ISP/Service: Comcast/Gigabit Internet
Cable Modem: Netgear CM1200 Cable Modem
--IEEE 802.3ad Dynamic LACP to--
Router: Netgear RAX200, Nighthawk Triband AX12, AX11000, Wifi 6
--2x 1GBE IEEE 802.3ad Dynamic LACP to--
10GbE Switch: Ubiquiti US-XG-16
--10GBE IEEE 802.3ad Dynamic LACP to--
Wired LACP Ethernet Clients Tested: Workstation w/ Intel ECNA X550, Synology NAS DS3615xs (mixed drives),
Wired Single 10GBE NIC Client Tested: 1x Desktop w/ Asus XG-C100C
Actual average speeds observed from internet sources: 920Mbps~1.1Gbps Down; 42Mbps~49.8Mbps Up
Actual internal network speeds observed: 600MBps~820MBps Read, 300MBps~500MBps Write.
--and Wifi/Wifi-6 to--
Wifi Clients Tested: iPhone 11 Pro Max, Dell 9700 w/ Wifi-6
Actual Average speeds observed from internet sources: 440Mbps~800Mbps
Actual internal network speeds observed: 200MBps~250MBps Read, 200MBps~250MBps Write.
- FURRYe38Aug 24, 2020Guru - Experienced User
Good to hear. Thank you for letting us know.
sterlingsanders wrote:I can officially say that this problem looks to be solved. I've had a little more than 78hours of uptime in Link Aggregation between the CM1200 and the RAX200. No drops in speed, no slow downs, no service interuptions and actually the speeds definitely feel more consistent in both wired and wireless clients.
