Pokemaniac
Jul 12, 2019Aspirant
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 an...
Aug 20, 2020Guru - Experienced User
Please report your findings in another day or two...
AdeptMaven wrote:Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
Cm1200>RAX120
AdeptMaven
Aug 24, 2020Guide
Happy to report that I've had Link Agg enabled for 5 straight days and no slow downs or other issues. Now just wish Intel could fix the AX200 drivers then all would be well in my network
- FURRYe38Aug 24, 2020Guru - Experienced User
THank you for letting us know. Glad this is fixed now.
You'll have to post about any Intel problems over in there forums and let them know.
Enjoy. :smileywink:
AdeptMaven wrote:Happy to report that I've had Link Agg enabled for 5 straight days and no slow downs or other issues. Now just wish Intel could fix the AX200 drivers then all would be well in my network
