Tonymontanaalb
Oct 11, 2021Tutor
CM1200 Spectrum Analyzer help
Hey everyone. Ive put in 192.168.100.1:8080 for the spectrum analyzer on the CM1200 modem and i get the following graph looking thing. looks like signal issues coming into the mdoem from the provider...
Oct 12, 2021Guru - Experienced User
1. why do you think you're having signal issues?
2. got a screensnip of the cable connections page and the event logs?
- TonymontanaalbOct 12, 2021Tutor
- plemansOct 12, 2021Guru - Experienced User
did you check your line/connections?
You don't have "errors" in your line per the screen snip (event logs tell us more......) but your power should be within 3.5dbmv of each other and you're running from -1 to 5.5dbmv. so a 6.5dbmv difference.
- FURRYe38Oct 12, 2021Guru - Experienced User
Also only 1 channel locked in?
Whats you uplink speed that you pay for?
