AdeptMaven
May 09, 2020Guide
CM1200 speed issues
I just set up a Netgear CM1200 modem and a Netgear RAX 120 Router four days ago. I have Comcast gigabit service (speeds up to a gigabit download, 35Mbs upload) and link aggregation between the two se...
Topology
May 11, 2020Virtuoso
AdeptMaven and Huskuldar, to clarify, you are observing the link aggregation performance problem when using the new RAX120 firmware 1.0.1.122 (together with CM1200 1.02.02 on Xfinity 1000Mbps service) - correct?
In addition, I am curious: have you enabled IPv6 on the RAX120?
Thank you.
Huskuldar
May 17, 2020Tutor
Yes, most current firmware, Xfinity 1gb service, IPV6 is enabled, link agregation disabled. After disabling link agregation service has been perfect.
