hxue91
Nov 11, 2024Aspirant
CM1200 stopped working with xfinity
My modem was working fine, but it stopped working after I moved to a new apartment. I tried contacting Xfinity support to activate it, but it is not working. I have tried restarting, resetting it, a...
Nov 12, 2024Guru - Experienced User
Had it worked before at the prior location?
hxue91
Nov 12, 2024Aspirant
It worked
- FURRYe38Nov 12, 2024Guru - Experienced User
Maybe something at this new location isn't working right. Would need a tech on site to help you check that.
- hxue91Nov 12, 2024Aspirant
My old modem works at the new location
- FURRYe38Nov 13, 2024Guru - Experienced User
If the CM worked on the old location and not the new location, then something at the new location isn't right with the ISP services at the new location. You'll need to have a friend or family member near by check the CM modem out at a different location to see if the problem follows or not.
