PineReach
Dec 17, 2019Tutor
cm1200 to Synology RT2600ac
I just replaced my old modem with a new CM1200 and I am having a little trouble. BTW, my isp is Comcast. On modem internet connection is Good. Ethernet Port Aggregation Status is checked but: Inacti...
- Dec 17, 2019
Interesting. I followed your procedure and here is the result:
Netgear CM1200 LAN1 to RT2600ac WAN good connection. <<current connection>>
Netgear LAN2 to RT LAN1 no connection. <<current connection>>
Basically everything reversed.
You are right about aggregation on the Synology. Probably looking at getting a new router.
Thanks!
Dec 17, 2019Guru - Experienced User
Feeling even more stupid. The more you research wan port aggregation for the synology the more it looks like its for dual wan with load balancing/fail over. Not wan aggregation. So you could have 2x devices such as a modem and a mobile router for fall back or load balancing.
Not very well documented on their part. You'd want to contact synology forums or support for more details on their wan side stuff.
BTW disabled wan port aggregation on the CM1200.
- plemansDec 17, 2019Guru - Experienced User
Reason I said disable it in the cm1200, is that from what I can read, wan port aggregation doesn't work with the synology.
You CAN run dual modems to it or modem-mobile router type setup with load balancing/fail over. But you can't run single modem setup to both wan and lan1 port.
again, this is just the brief research I did on the synology router. They'd be the experts on their device.
but unless you have a router with true wan port aggregation, having the cm1200 port aggregation enabled/connected will cause issues with the cm1200.
