PineReach
Dec 17, 2019Tutor
cm1200 to Synology RT2600ac
I just replaced my old modem with a new CM1200 and I am having a little trouble. BTW, my isp is Comcast. On modem internet connection is Good. Ethernet Port Aggregation Status is checked but: Inacti...
- Dec 17, 2019
Interesting. I followed your procedure and here is the result:
Netgear CM1200 LAN1 to RT2600ac WAN good connection. <<current connection>>
Netgear LAN2 to RT LAN1 no connection. <<current connection>>
Basically everything reversed.
You are right about aggregation on the Synology. Probably looking at getting a new router.
Thanks!
Dec 17, 2019Guru - Experienced User
Try this.
Factory reset both the CM1200 and the synology.
Boot up the CM1200 with nothing connected. Give it a few minutes to fully boot.
then plug port 1 from cm1200 into the wan 1 port on synology.
Then boot it up and factory install it.
You said the cm1200 worked when your computer was directly connected. Thats a good sign.
Are you able to access the synology?
Not an expert with their devices which is why I'd recommend a factory reset to ensure no prior settings are causing issues.
PineReach
Dec 17, 2019Tutor
Thanks!
