wfulton2
Oct 21, 2023Aspirant
cm1200 upstream randomly will start blinking intermittently and lose internet
Spectrum says its not on there end to check with Netgear. here is my event log though. Sat Oct 21 15:45:15 2023 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N...
- Oct 22, 2023
Power levels are with in spec:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
However you have a ton of Correctables and Un-correctables that should be most zeros
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Oct 21, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
What is the brand and model of the host wifi router connected to the modem?
