jay_w
Mar 13, 2024Apprentice
CM1200 WAN aggregation slows down (requires reboot)
A few days back, I realized WAN aggregation was the only way I could get total bandwidth to use my 1.2gbs xfinity service due to the 1gbs ports on my CM1200. I successfully enabled WAN aggregation ...
Mar 13, 2024Guru - Experienced User
Are the speeds good with out WAN Agg being enabled?
Might post your CM modems cable connections and event log data please.
I successfully enabled WAN aggregation and my download throughput jumped from 940mbs to 1.4gbs. I was over the moon thrilled in a house full of streamers.
But then.. in Netgear style. After 24 hours my download test dropped to 800mbs. WTF right? I checked WAN configuration was active 1gbs + 1gbs, and I rebooted my modem. Magically it was 1.4gbs again. I tried a few hours and everything was good. Woke up this morning and back down to 800mps.
Apparently.. this is common to the CM1200 with several different routers. But I can’t find a resolution. This is complete trash. I bought top of the line at the time and I’m ready to switch away from Netgear. Any help?
