Woodn
Mar 28, 2020Aspirant
CM1200 Wifi wont work
Just got my CM1200 and plugged it in, but only the power light shines green. the wifi and others either are off or flash green or yellow. my isp cannot detect my modem and set it up. please help
- Mar 29, 2020Yeah, I know its not a router, im talking about the "online light" that wont light up
I figured out the problem anyway, the coaxial running through my house isnt working
Mar 29, 2020Guru - Experienced User
1. the cm1200 doesn't have wifi. Its a modem only device.
2. go to netgear.com/support/ type in your model number. it'll take you to the support site with your manual. list exactly what each light is and is doing.
3. did you hook up the coax to the cm1200?
4. are you activating over the phone, usine auto-activate, what exactly are you doing?
5. if you log into the cm1200 (192.168.100.1) what does the connections page show? (take a screen snip)
6. The cm1200 has 4 ports. the average home consumer can only use 1. port 1 and 2 can be aggregated together but only if your router supports that (most don't). the other ports are useful if your ISP allows multiple public ip addresses (most don't).
- WoodnMar 29, 2020AspirantThat page is blank when I type it in
The wireless light is off and cant be detected by my isp- plemansMar 29, 2020Guru - Experienced User
The wireless light is off and cant be detected by my ispThere is NO WIRELESS light. It does not have wireless if you have the CM1200.
Look up the manual. It describes the lights. what they are, what each means.
- WoodnMar 29, 2020AspirantYeah, I know its not a router, im talking about the "online light" that wont light up
