Woodn
Mar 28, 2020Aspirant
CM1200 Wifi wont work
Just got my CM1200 and plugged it in, but only the power light shines green. the wifi and others either are off or flash green or yellow. my isp cannot detect my modem and set it up. please help
- Mar 29, 2020Yeah, I know its not a router, im talking about the "online light" that wont light up
I figured out the problem anyway, the coaxial running through my house isnt working
Mar 29, 2020Guru - Experienced User
Woodn wrote:
That page is blank when I type it in
The wireless light is off and cant be detected by my isp
There is NO WIRELESS light. It does not have wireless if you have the CM1200.
Look up the manual. It describes the lights. what they are, what each means.
