TedBoy
Jun 30, 2023Aspirant
CM1200 with WOW ISP
Installed new CM1200 modem on WOW service in mid-April 23. All good for a few days, then intermittent connection issues started and got worse and worse into June. Did online tech support with Netge...
TedBoy
Will get log data when I get to the location with the CM1200. However, what would allow 2 different WOW owned modems to work flawlessly at my location when the CM1200 does not? The router is an eero AX1800, and I have also changed to 2 different Apple routers during the 2 months of problems to test, but none of that has made a difference. This has been going on for 2 months with much effort to fix? Thanks
Jun 30, 2023Guru - Experienced User
Can't do much more until we see the logs.
Other things you can do:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed by the ISP and resolved. These indicate a ISP signal line issue on there side of the modem
https://highspeed.tips/docsis-events/
- KitsapJun 30, 2023Master
When you get to the location with the CM1200, make sure the ground connection at the box where the coax enters the house is tight, and clean. Some ISP techs may check for this and others do not.
